For some reason my shake is offline but reading connected on RSlocal.
Hi Labrina, sorry for the inconvenience. Your Shake is now back online:
https://raspberryshake.net/stationview/#?net=AM&sta=R359E
Hi, I have the same issue: RB972RSH.RB972.2020-09-23T17 47 53.logs.tar (4.0 MB)
everything looks fine to me:
https://raspberryshake.net/stationview/#?net=AM&sta=RB972
your unit was having DNS issues, preventing successful connection to the server, but this seems to have resolved itself now.
Thanks Richard,
It still says station offline on āmy shakeā on shakenet and on the shakenet app. Am I missing something?
Apologies for the newbie type questions, it only arrived today!
hi,
propagating a station coming on-line throughout the system can take a few hours, patience is key.
your shake is online now in the mobile app, and should also be on-line on the āmy shakeā page.
Hi, our station AM.R7BF6 is also offline. The station has been already on and sending data to swarm for a week and it appears as activated and connected in rs.local, but it still doesnāt appear in the station map, and in the mobile app appears as offline. Any idea about which might be the problem?
Cheers,
Pablo
Hello Pablo, welcome to the community!
Could you please post the logs from the Shake?
They are downloadable from the Raspberry Shakeās web configuration page, accessible entering the rs.local address in your browser, then by clicking on the āDownload Logsā button.
Me again!
My skake ran for a couple of weeks but then whilst away with work, it seems to have disconnected from the server (around the 30th September).
| Data Producer | : | ON |
| Data Consumer | : | ON |
| Stand-Alone | : | OFF |
| Data Forwarding | : | ON |
| Server Connection | : | Not Connected |
Iām not clever enough to decipher the logs, can anyone help me diagnose?
Thanks
MattRSH.RB972.2020-10-12T15 31 32.logs.tar (4.0 MB)
Hello Matt,
From the postboot.log file, these lines explain the issue as a DNS problem, where the Shake cannot reach our servers:
2020 286 14:49:51: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
2020 286 14:49:51: No internet connection found
2020 286 14:50:02: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
The first thing you can try (if you havenāt already) is simply to shut down your Shake from the rs.local web interface, then your modem/router, wait a couple of minutes, and then turn on again the modem first and the Shake second, to see if it was a simple issue with the modem/router itself.
If this does not happen, then you can also try to change the DNS on the Shake, as explained in this page on our manual, https://manual.raspberryshake.org/firewallIssues.html#how-to-manually-change-dns, to see if this solves the issue. Iāll add some more info below.
The first doesnāt require logging into the Shake. Navigate to
rs.local, make note of the Shakeās IP address, then click on theSettingsgear icon (high on the left) to access the configuration menu.Click on NETWORK, then under ETHERNET SETTINGS, click on āEnable static IPā.
Fill out the DNS server field with a more reliable DNS service.
OpenDNS, which is208.67.222.222, is a good choice. You can also useCloudflareDNS service by entering1.1.1.1orGoogleby entering8.8.8.8.
SSH into the Shake (guide here: https://manual.raspberryshake.org/ssh.html)
Once youāre in, copy and paste these commands (this example is for Cloudflare DNS):
sudo echo 'static domain_name_servers=1.1.1.1 1.0.0.1' >> /etc/dhcpcd.conf sudo service dhcpcd restartNow make sure those changes took hold:
nano /etc/resolv.confThe file should look like the following:
# Generated by resolvconf nameserver 1.1.1.1 nameserver 1.0.0.1
Sorted after a few headaches. Turned out my router had gone haywire & decided to only route internal traffic on some sockets, so I could look at it locally but it couldnāt see the outside world.
Very random! Thanks for your assistance, I would have just been chasing my tail for weeks!
Matt
Unusual and random indeed, but glad that you could solve the problem!
Can you tell us the brand and model of your modem/router? So we can have a reference for eventual future users. Thank you.
It was a router provided by Plusnet in the UK (not entirely sure what it was). Now slung in the bin and replaced with a Draytek 2862.
Thanks
Matt
I have the same issue, station not showing up on StationView, with R532B. Itās been a few days.
RSH.R532B.2020-10-21T04 29 56.logs.tar (1.3 MB)
Hello jeffersonite, welcome to the community!
Thank you for posting your logs, from them I am seeing that the boot procedure seems to work fine, and your Shake is properly working after that. So the issue has to be on the connectivity side.
If this doesnāt work, then shut down your Shake again first, then your modem/router. Wait for a couple of minutes, then restart your modem/router, and when itās back online, please check from your pc/laptop if the following ports are open (do not start the Shake now):
port 55555 [TCP]
port 55556 [TCP]
After checking this, and opening the ports, if needed, please start your Shake, wait for around 10 minutes, save the logs again, and then send them back to me, so I can see if there are any differences in them compared to the original ones.
Now itās best to check that your unit can reach our servers so, can you try to SSH into the Shake by entering this command in a prompt (with admin authorization)?
If during the configuration you have changed the password, you should input that one, and not the provided default (which is shakeme).
Once you are in, can you try and ping the following addresses?
ping 8.8.8.8 -c 10ping 104.200.16.60 -c 10
Iāll wait for you to try this and your new logs before going forward.
Hi @Stormchaser,
Thank you for the detailed reply, but I did all of that before I sent the logs the first time. This unit can ping 104.200.16.60, has open firewalls, and is recording data fine.
I got an automated email saying that the RS server hasnāt seen this unit in 3 days (the day I first turned it on), so it must have communicated successfully at some point.
I might have another unit that is also having the same issue, but I havenāt heard back from the enduser yet.
I have a few more of them to deploy, some at not so accessible places, so itād be nice for it to just work the first go-around. What are the server-side issues that might result in this behavior?
Thanks,
Jefferson
Hello again Jefferson,
All right, thank you for that. I will ask our server team about this, and as soon as Iāll get details from them Iāll update you.
It is totally understandable, and normally they work from the get-go (as mine did). Iāll get back as soon as I can.
Hello Jefferson,
I just got back an answer from the team, and they were able the solve the issue.
Now your station transmits successfully, and it is visible bot on StationView and our ShakeNet app.
Excellent! Thank you! What was the issue?
