Hi all, I recently assembled an RS1D, using a Raspberry Pi 4 Model B (2 GB RAM) as the computer board. I can’t access the Pi at rs.local and it doesn’t appear in Fing. The blue light is on the shake board, and the red light is consistently on indicating that it’s getting power.
The green light on the Pi board however is flashing 4 long flashses, followed by 4 short flashes. This repeats every 15 seconds or so. Reading online, it looks like this might indicate that the Pi board is “not supported” (see here). I’m not sure why this is the case given that the board is one of the recommendations for the DIY setup.
For testing purposes I tried two different SD cards (one that shipped with the DIY kit and one consumer-grade one I had lying around). I also tried both copying the files from the release.zip file onto the SD card and burning the disk image onto the card via the Raspberry Pi Imagery, both result in the same green light flashing pattern.
The resolution might be that the disk image needs to add support for my particular Model B board? I guess there are different revisions out there? Any ideas?
Edit: I downloaded the 0.20 image from here and verified the MD5 matches.
