After following your instruction. Still not working . Hoping you can help me resolve this problem
Hello waw0102,
Could you please try adding a question mark to the end of the new address you’ve pasted in the RSUDP file?
On the same line (518), changing from this .../query' % ( to this /query?' % (
And see if this now allows RSUDP to retrieve the inventory file correctly? I can confirm that your Shake’s response file is present on our system: https://stationview.raspberryshake.org/fdsnws/station/1/query?level=resp&network=AM&station=R24FA
