I finally got it to work after a few hours using a 3B and a 16Gb MLC card, [default settings] but getting these errors on loading.
pi@raspberrypi:~ $ conda activate rsudp
(rsudp) pi@raspberrypi:~ $ rs-client
Qt import failed. Trying Tk…
detail: No module named ‘PyQt5’
2021-03-24 20:15:24 [Main] Logging initialized successfully.
2021-03-24 20:15:24 Using settings file: /home/pi/.config/rsudp/rsudp_settings.json
2021-03-24 20:15:24 Output directory is: /home/pi/rsudp
2021-03-24 20:15:24 [Init] Initializing.
2021-03-24 20:15:24 [openSOCK] Opening socket on localhost:8888 (HOST:PORT)
2021-03-24 20:15:24 [Init] Waiting for UDP data on port 8888…
2021-03-24 20:15:26 [Init] Available channels: [‘EHZ’]
2021-03-24 20:15:26 [get_inventory] WARNING: No station name given, continuing without inventory.
2021-03-24 20:15:26 [conn_stats] Initialization stats:
2021-03-24 20:15:26 [conn_stats] Port: 8888
2021-03-24 20:15:27 [conn_stats] Sending IP address: 192.168.2.203
2021-03-24 20:15:27 [conn_stats] Set station name: Z0000
2021-03-24 20:15:27 [conn_stats] Number of channels: 1
2021-03-24 20:15:27 [conn_stats] Transmission freq.: 250 ms/packet
2021-03-24 20:15:27 [conn_stats] Transmission rate: 4 packets/sec
2021-03-24 20:15:27 [conn_stats] Samples per second: 100 sps
2021-03-24 20:15:27 [Plot] WARNING: Running on armv7l machine, using Tk instead of Qt
2021-03-24 20:15:27 [Plot] Plotting 1 channels: [‘EHZ’]
2021-03-24 20:15:27 [Plot] Seismogram units are channel-specific
2021-03-24 20:15:27 [Plot] Starting.
2021-03-24 20:15:27 [Alert] Alert stream units are counts
2021-03-24 20:15:27 [Consumer] Starting.
2021-03-24 20:15:27 [Producer] Starting.
2021-03-24 20:15:27 [Producer] Receiving UDP data from 192.168.2.203
2021-03-24 20:15:27 [Alert] Starting Alert trigger with sta=6s, lta=30s, and threshold=1.7 on channel=EHZ
2021-03-24 20:15:27 [Alert] Earthquake trigger warmup time of 30 seconds…
2021-03-24 20:15:28 [Plot] WARNING: Failed to set PNG icon image, trying .ico instead
2021-03-24 20:15:57 [Alert] Earthquake trigger up and running normally.
2021-03-24 20:17:22 [Alert] Threshold: 1.7; Current max STA/LTA: 1.5709
It works so I assume these don’t matter,
Lastly, I can’t save the edited the settings json file, I get permission denied, hence no station name etc
Any help much appreciated as I;m total newbie on raspberry os.
Thanks goes to hcintronBeta Tester
rsudp-installation-error
Post was a great help.
phil
