Hello
I would like some help to open the web menu. http://rs.local/ is not working.
Kind regards,
Amanda Mendes
Hello
Kind regards,
Amanda Mendes
The .local domain is not terribly reliable, especially on Windows.
Check to see if you can determine the IP address allocated to your shake and use that rather than “rs.local”.
Try Angry IP scanner software, easy to use and free…
Marco
Hello mendesamanda, and welcome to our community!
Regarding your issue, you can also try to find the IP address of your Shake (to access it in place of rs.local/) via the admin panel of your modem/router, or, in case you do not have permissions to see it, with the app Fing. We explain how to use it in the Troubleshooting section here: Please read before posting!
