Replaced RaspberryPi
Exactly what I needed, thank you very much reelfoot.
Now, could I ask you to do the following?
  1. Shut down the Shake
  2. Disconnect power and LAN cables, wait for 5 minutes
  3. Reconnect LAN and power cables (in this order) and turn on the Shake again
  4. Wait for ~30 minutes, download the logs from the Shake (if needed, instructions here: Please read before posting! ) and attach them to your next answer?
I would like to compare the new logs after a fresh start with the ones you’ve just sent me.
Thank you again!
