R884B missing from Station View
My rPIboom is working and Swam displays data normally.
I received an email warning me you receive no data from my Pi for 3 days.
I’ve downloaded the logs, had an overview over them, /opt/data/{archive,gifs} got datas up to this current date.
I can log into the pi.
SDcard use is at 48%, with 3.8Gb free.
Resolving your host from the Pi works as well.
I tried a reboot, nothing better.
I think the bork started when I tried to modify my pi geoposition + altitude on the settings map (http://myshakeip/config)
Data Producer : ON
Data Consumer : ON
Stand-Alone : OFF
Data Forwarding : ON
Server Connection : Connected
swarm continues to work after each reboot, but data is not transmitted.
What can I do ?
regards,
Alex
hi alex,
thanks for the report, we are looking into this and will get back to you.
Hello Alex, welcome to our community!
While we investigate, could you please send us the logs from your Shake? The instructions on how to download them are here: Please read before posting!
In this way, we will have a complete view on what could be happening, both from our side and from your side.
Thank you for your replies. The device started to publish again yesterday 21/09 around 20h38 UTC. I opened earlier this request as I received an email warning me there was no datas received by your server, which is a nice feature.
Tell me if you need still the logs.
Hello Alex,
Thank you for your confirmation. Your BOOM is now visible and transmitting live data on StationView here: RS StationView
There was no need for the logs, in the end, since we found that the issue was a server-side one, and our team was able to correct it.
Thank you for your patience, and enjoy your infrasound sensor!
RSH.R892F.2021-12-31T09_10_26.logs.tar (565 KB)
Hello, I have a similar problem here. As far as I can see from the log files it seems that the connection to the server is working. however, the station is not visible and data is not accessible. Could you please help? Thanks
Hello manconi, welcome to our community!
Thank you for posting both logs and the screenshot. From them, it seems that the Shake can see and communicate with our servers, but is not connecting for some reason.
Could you please reboot the Shake and then try the following procedure to see if it solves the connectivity issue?
Thanks for your reply. I have done the suggested procedure, but the situation has not changed.
Thanks for any advice.
Hello manconi,
Thank you for getting back to me. Sorry to hear that this fix has not worked. There must be something else that is preventing connection then.
Could you please shut down the Shake, wait for ~5 minutes, turn it on again, wait for around ~30 minutes, and send me the new logs?
I would like to check if there is something preventing connection with a fresh start, and compare this log set with the other one you sent me.
Hi
unfortunately I am in home office and the RS is not physically accessible…do you have any other suggestion I can apply from remote? Thanks
if you have remote access, you can reboot your Shake instead of shutting it down. Then wait for the mentioned ~30 minutes, download the log again and then post them here.
It would be almost the same and it could help in pinpointing where the issue is.
RSH.R892F.2022-01-03T20_20_30.logs.tar (1013 KB)
Here they are. Thanks
Hello again,
Thank you for the updated logs. It doesn’t appear that there are connection problems, since the unit can is able to see our servers, at least from the results that I am able to see.
Could you please SSH (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake ) into the Shake and try and ping the following addresses?
  • ping 8.8.8.8 -c 10
  • ping raspberryshakedata.com -c 10
I have also noticed, from the logs, that the disconnection happened around the first of January. In your knowledge, has something in the local network to which the Shake is connected to been reset on that day?
Hello
here the result of the ping
myshake@raspberryshake:/opt $ ping 8.8.8.8 -c 10
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=5.08 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=5.12 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=5.14 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=5.18 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=5.04 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=117 time=5.00 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=117 time=4.100 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=117 time=4.98 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=117 time=4.99 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=117 time=5.17 ms
— 8.8.8.8 ping statistics —
10 packets transmitted, 10 received, 0% packet loss, time 20ms
rtt min/avg/max/mdev = 4.978/5.070/5.181/0.097 ms
myshake@raspberryshake:/opt $ ping raspberryshakedata.com -c 10
PING raspberryshakedata.com (144.91.66.87) 56(84) bytes of data.
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=1 ttl=56 time=25.0 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=2 ttl=56 time=25.1 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=3 ttl=56 time=25.2 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=4 ttl=56 time=25.0 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=5 ttl=56 time=25.1 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=6 ttl=56 time=24.10 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=7 ttl=56 time=25.0 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=8 ttl=56 time=25.0 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=9 ttl=56 time=25.0 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=10 ttl=56 time=25.0 ms
— raspberryshakedata.com ping statistics —
10 packets transmitted, 10 received, 0% packet loss, time 19ms
rtt min/avg/max/mdev = 24.993/25.044/25.158/0.084 ms
The problem has appeared after I have tried to set a static IP address. I noticed that the RS was not online anymore and I set back to DHCP removing the parameters from /etc/dhcpcd.conf. Since then it doesn’t work. Here below the current configuration in /etc/dhcpcd.conf:
#controlgroup wheel
clientid
or
#duid
persistent
Rapid commit support.
option rapid_commit
option ntp_servers
Respect the network MTU.
#option interface_mtu
slaac private
#nohook loo
denyinterfaces wlan0
Hello again,
I’m happy to see that the Shake can see and communicate with our servers from the ping results. And yes, the dhcpcd.conf is likely the cause of the issue you are experiencing. I will open a ticket so that this possible bug with the setup of a static IP address can be examined further.
In the meanwhile, you can try to do the following. Please open the dhcpcd.conf file with
sudo nano /etc/dhcpcd.conf
and add this line at the very beginning of the file: interface eth0. Do not modify anything else.
Save the edits, and then do:
sudo service dhcpcd restart
nano /etc/resolv.conf
Now restart your shake and let it retrieve its new network settings through DHCP. This should solve your connection issues.
If the connection status still remains, not connected, then please try this procedure:
If the Shake still does not connect, then, unfortunately, the only other step I can recommend is to re-burn the microSD card, to start with a fresh system and erase any possible corrupted files that may have formed.
Thanks for your reply! I have done all steps and now the RS shows up as “Connected” in the rs.local page. Still, the Station does not appears in the station.view page, but I guess this might need some time.
Cheers, Andrea
Hello Andrea,
It’s great to hear that, glad that I could help!
Yes, it may take up to 24h for a new connected unit to show on our services, and your station is now visible on our services.
Have a good weekend!
