I installed the RS1D DIY version today (using Raspberry PI 4B),
and I found that no data is generated on webui.
I using 5.1V 3A power supply.
RSH…2021-03-03T11_54_41.logs.tar (430.5 KB)
Hello Akari, welcome to the community!
We know of this issue, and our team is working to solve it. Thank you for your report. and for the logs. From them, it appears that your revision number “b03114” is not (yet) among the ones that the current Shake OS release supports.
However, don’t worry, there is a way to solve the problem explained in this post: Stuck on config screen - #6 by ivor
Our next Shake OS release will likely address this problem.
It’s running now, Thanks!
Great news Akari!
As you can see, the Pi Model is (as of now) listed as Unknown. This will change with the next Shake OS release, but glad that is working for you too!
Enjoy!
