Stuck on config screen
hi,
good to hear the first problem resolved itself, sorry to hear you have a new one. your model number is a recent 4ModelB release that the system doesn’t know about yet. (this lag within the system is being addressed in the next release.)
in the meantime, you will need to make one slight adjustment by hand to get the system to work for you. please log in to the Shake’s Pi and issue the following commands:
> sudo rm -f /dev/ttyAMA0
> sudo ln -s /dev/ttyS0 /dev/ttyAMA0
> sudo reboot
after the reboot, the data will be read off the correct serial port and everything should work as normal.
please let me know if you experience any other issues.
cheers,
