Live Data Issues
Raspberry Shake Data Center Services: Status Update
Realtime streaming
:white_check_mark:[ ONLINE ] stationview.raspberryshake.org
:white_check_mark:[ ONLINE ] instrument file download (via StationView)
:white_check_mark:[ ONLINE ] dataview.raspberryshake.org
:white_check_mark:[ ONLINE ] ShakeNet Mobile App (Android / iOS)
:x:[ OFFLINE ] SWARM*
:x:[ OFFLINE ] ShakeNet Portal
Legacy data
:x:[ OFFLINE ] DataView
:x:[ OFFLINE ] FDSNWS (this affects ObsPy routines)
:x:[ OFFLINE ] 24-hour waveform download via StationView
:x:[ OFFLINE ] EQSound and EQLocator
The process of switching over to the new Raspberry Shake server infrastructure is in progress. We will keep everyone posted in the coming days. Thank you for your continued patience.
The next update is coming on Friday, April 12th, 2024 (or as soon as the switching process is complete).
(*) Until SWARM is brought back online, we recommend using dataview.raspberryshake.org , our web app with SWARM-like functionality
Realtime streaming
:white_check_mark:[ ONLINE ] SWARM
Legacy data (Available from current date to February 8th, 2024)
:yellow_square:[ ONLINE ] SWARM
:yellow_square:[ ONLINE ] DataView
:yellow_square:[ ONLINE ] FDSNWS (this affects ObsPy routines)
:yellow_square:[ ONLINE ] 24-hour waveform download via StationView
The new Raspberry Shake server infrastructure is in place, and the migration process has been successful. Real-time data is available, and legacy data is also available from the current date back to February 8th, 2024, as described in the list above.
What’s next?
  • Main focus: Bring our entire legacy Shake Network data archive back online.
  • Restore ShakeNet, EQLocator, EQSound Web Apps.
  • Continue increasing the performance and resilience of our system infrastructure.
From all of us here at Raspberry Shake, we wish to thank all Shakers for the support, patience, and understanding demonstrated during these trying times. It’s great to be a part of all this!
The next update will be on Friday, April 19th, 2024 (or as soon as other objectives are reached).
Realtime streaming
Real-time data continues to be available, and legacy data is also available from the current date back to February 8th, 2024, as described in the list above. We continue our work to bring our entire legacy Shake Network archive back online and restore the functionality of currently not-working web apps.
The next update will be on Friday, April 26th, 2024 (or as soon as other objectives are reached).
Realtime streaming
:yellow_square:[ ONLINE ] EQSound and EQLocator
A quick update to highlight that EQSound and EQLocator functionality has been restored, with data back to February 8th, 2024. We continue to work on the restoration of Data Center Services.
Realtime streaming
We are continuing our work to fully restore live data to the ShakeNet portal and legacy data older than February 8th, 2024.
The next update will be on Friday, May 3rd, 2024 (or as soon as other objectives are reached).
Realtime streaming
We are aware of and working on an issue that is preventing continuous live data streaming from being displayed on StationView and DataView, while continuing our effort on legacy data restoration. Thank you so much for all the support messages we are receiving!
The next update will be on Friday, May 10th, 2024 (or as soon as other objectives are reached).
Realtime streaming
We continue to work to fix the issues described in previous messages and are progressing towards a complete resolution of this situation. Thank you for your continued patience and support.
The next update will be on Friday, May 17th, 2024 (or as soon as other objectives are reached).
Realtime streaming
Legacy data synchronization continues while we work to restore all ShakeNet past recordings. We are also continuing to work on the issues described in previous messages.
The next update will be on Friday, May 24th, 2024 (or as soon as other objectives are reached).
Realtime streaming
We are actively addressing an issue affecting continuous live data streaming on StationView and DataView. Simultaneously, we are progressing with restoring legacy data and synchronizing all past recordings. We appreciate your continued patience and support.
The next update will be on Friday, May 31st, 2024 (or as soon as other objectives are reached).
Realtime streaming
We have implemented a fix to solve the continuous live data streaming issue on StationView and DataView. Legacy data restoration and the synchronization of all past recordings are progressing steadily. Thank you.
The next update will be on Friday, June 7th, 2024 (or as soon as other objectives are reached).
Realtime streaming
:white_check_mark:[ ONLINE ] StationVIew (stationview.raspberryshake.org)
:white_check_mark:[ ONLINE ] DataView (dataview.raspberryshake.org)
A further fix has been implemented to stabilize live data streaming on all platforms (StationView, DataView, and the mobile App) and we are satisfied with current performance. A further update about legacy data access will likely be provided next week. Thank you.
The next update will be on Friday, June 14th, 2024 (or as soon as other objectives are reached).
