Jessie distribution and GPS
Hello Hugo, and welcome to our community!
You could install our latest Shake OS version (which is based on buster) so that you can see if there are drivers available for the GPS modules that you have. If you choose to do so, I’ll leave the microSD card burn instructions here for your convenience:
If this doesn’t work, then you can try to update the OS of the latest image above, paying attention to verify that all the Shake OS functionalities are still in working order. You don’t have to worry about making mistakes, as you can always re-flash the microSD card and start anew.
In the case this still does not work and drivers are still not available for your GPS, I would then recommend acquiring the ones we provide in our shop (GPS Antenna | Accessories), which are tested and proven to work with our Shake OS.
