We have software that will do a similar function by using the UDP datacast from the Shake. However instead of using a linear alarm parameter like 60 um/s, it uses a STA/LTA sudden motion algorithm, which can be filtered and tuned as necessary. It can also play an alert sound, save images of data, send tweets, and count events when the alarm threshold is exceeded.
