I already tried all the errors by installing that, that’s why I opened another case.
The first thing I do is install the RS O.S, downloading the file from this link: raspberryShake-public / Raspshake Sd Img · GitLab
Then I pass this file to a 16GB class 10 formatted SD, I unzip the file and then I pass it to RS4D, I wait approximately 15 minutes, when it finishes and I can finally enter http://rs.local, where I configure and share the data.
I make my connection through SSH, I install miniconda3 from this link: Install Miniconda 3 on Raspberry Pi · GitHub
Later I do the video tutorial:
git clone https://gist.github.com/simoncos/a7ce35babeaf73f512be24135c0fbafb
cd rsudp
bash unix-install-rsudp.sh
It tells me that I have a miniconda error and that it cannot create the environment, then what I do:
conda create --name rsudp python=3.4.3 #Is the version that installs rsudp
This says that the address does not exist: /home/myshake/.config/rsudp/rsudp_settings.JSON
I create it manually:
cd /home/myshake
mkdir .config
cd .config
mkdir rsudp
cd rsudp
sudo nano rsudp_settings.JSON
And right there I copy this data:
"settings": {
"port": 8888,
"station": "Z0000",
"output_dir": "/home/myshake",
"debug": true},
"printdata": {
"enabled": false},
"write": {
"enabled": false,
"channels": ["all"]},
"plot": {
"enabled": true,
"duration": 90,
"spectrogram": true,
"fullscreen": false,
"kiosk": false,
"eq_screenshots": false,
"channels": ["all"],
"deconvolve": true,
"units": "CHAN"},
"forward": {
"enabled": false,
"address": ["192.168.1.254"],
"port": [8888],
"fwd_data": true,
"fwd_alarms": false},
"alert": {
"enabled": true,
"channel": "HZ",
"sta": 6,
"lta": 30,
"threshold": 3.95,
"reset": 0.9,
"highpass": 0.8,
"lowpass": 9,
"deconvolve": false,
"units": "VEL"},
"alertsound": {
"enabled": false,
"mp3file": "doorbell"},
"custom": {
"enabled": false,
"codefile": "n/a",
"win_override": false},
"tweets": {
"enabled": false,
"tweet_images": true,
"api_key": "n/a",
"api_secret": "n/a",
"access_token": "n/a",
"access_secret": "n/a",
"extra_text": ""},
"telegram": {
"enabled": false,
"send_images": true,
"token": "n/a",
"chat_id": "n/a",
"extra_text": ""},
"rsam": {
"enabled": false,
"quiet": true,
"fwaddr": "192.168.1.254",
"fwport": 8887,
"fwformat": "LITE",
"channel": "HZ",
"interval": 10,
"units": "VEL"}
From there I try the command again:
cd rsudp
Then I have errors with gpsd and saw that error is fixed by what stormchaser says here: Gpsd missing, not started at boot
#ListenStream=[::1]:2947
Then I no longer get errors, until almost at the end, it says that scipy is missing something, I fix it, and it shows me the same thing but with another code, I saw that it is not compiled and that is why I have error after error, try:
python3 -m pip install scipy
udo apt-get install gfortran
and it got to a point where it got stuck running pcipy from wheels.
