As soon as I installed to my sd card when I located with fling the raspberry shake device and connected the to the rs.local page no status , model name etc. are shown… all is empty.
Anyone might know how to configure this issue ?
Hello Titanas, welcome to the community!
Oh, this seems quite unusual, but let’s see what we can do about it.
What operative system and browser are you using?
When you used Fing it should have given you a local IP address (like, for example, 192.168.1.47 or 10.10.something.something). Have you tried to connect to that address directly (by writing it in the browser address bar and pressing enter) instead of rs.local?
If you are able to connect via this way, can you then click on Download Log Files and post them here for us to check? Thank you.
Hello, thank you! sorry for my late reply,
I am using Windows 10 32-bit and chrome browser.
Yes Fing has given me another IP address which connects me to the same page.
I was able to download the log files and i attach to this message.RSH…2020-09-24T06_50_38.logs.tar (371.5 KB)
Fing recognizes the model of the raspberry.
Thank you in advance,
Kind regards, Titanas
Hello Titanas, no problem.
Ok, having access via IP address is good, and the fact that it recognizes the Raspberry Pi is again a positive news.
From your logs it appears that the Shake OS cannot find the Pi Board and the sensor attached to it. If you notice the name of the log files does not have your station code between RSH and the date .These lines in postboot.log explain the issue:
2020 268 06:46:55: Setting Serial Port Name: HW Revision: a02082 / Port Name: /dev/ttyS0
2020 268 06:47:11: Unable to read Firmware version number off of Serial Port /dev/ttyS0 after trying for 15 seconds, cannot continue!
2020 268 06:47:11: Is the Pi computer connected to the Raspberry Shake Board? Please confirm and try again.
Did you assemble the Shake by yourself? Can you please check that every connection between the sensors, the blue Shake board and the Raspberry Pi are in the proper place and solid?
The Shake board should sit on pins 01 through 26 on the Raspberry Pi, as shown on this section of our manual: https://manual.raspberryshake.org/specifications.html#ip67-m12-connector-specifications
If you feel that they could be useful, you can also post some pictures of the Shake from different angles, so maybe it could be faster to spot any inconsistencies.
thank you for all the pictures you’ve sent. Yes, the Shake appears fine, with all the connections in the right places.
From your photos, I am also seeing that the lighting on your Shake seems the correct one, with red and blue LED on the boards and green and orange on the LAN port. I cannot see the green LED near the red one, but since it blinks every now and then maybe it just wasn’t in the pictures.
The only thing that I can advise now is to burn again the microSD card. The process is quite simple, and listed in these steps:
If this does work, then the Shake will boot up again fine and you should be able to see the details in the rs.local page.
Yes the green blinks and i didnt caught it on pic.
I followed your instructions but the same issue occurs.
I attach the log files also. RSH…2020-09-25T08_35_14.logs.tar (40 KB)
Thanks,
Thank you for the log files, and yes, it seems that we have the same identical condition.
I have passed the issue to our software/hardware teams, and I will update you as soon as I have news.
I wrote an email to you Titanas, so we can continue our discussion there.
ok thank you, will check now
Hello Stormchaser,
I’m having the same problem with the 4D board.
Attached is the log file RSH…2020-10-28T03 30 57.logs.tar (82.5 KB)
Please advice.
Thanks in advance.
Hello harry.bangkit, welcome to the community!
Thank you for posting the logs of your Shake. From them, I can see that, indeed, the Shake OS cannot find the Pi Board and the sensor attached to it. If you notice the name of the log files does not have your station code between RSH and the date .These lines in postboot.log explain the issue:
2020 302 03:14:29: Setting Serial Port Name: HW Revision: a02082 / Port Name: /dev/ttyS0
2020 302 03:14:45: Unable to read Firmware version number off of Serial Port /dev/ttyS0 after trying for 15 seconds, cannot continue!
2020 302 03:14:45: Is the Pi computer connected to the Raspberry Shake Board? Please confirm and try again.
Did you assemble the Shake by yourself? Even if you received a pre-assembled unit, can you please check that every connection between the sensors, the blue Shake board and the Raspberry Pi are in the proper place and solid?
Also, can you confirm that the following lights are active when you turn on the Shake?
We will proceed forward once these checks are done.
Hi Stormchaser, thanks for your response.
I think I know where the problem is, when I open ttyS0 using minicom no characters appear on the screen, but when I change to /dev/serial0 a lot of characters come out to the terminal i.e "{“MA”: “RS4D-8-4.11”,“DF”: “1.0”,“CN”: “EN3”,“TS”: 0,“TSM”: 0,“TQ”: 45,“SI”: 5000,“DS”: [“35 …”
So I think if I can change rpi-shake config to /dev/serial0 the shake will work.
Could you tell me how to change the serial port on rpi-shake app?
Hello again,
Glad to hear that the issue has been solved!
Your idea was spot on, could you please explain what you did step by step so if other users have the same problem can follow your approach? Thank you!
Hi Stormchaser, you’re welcome!
This link helped me solve the problem, which explains alot. I just need disable bluetooth ““pi3-disable-bt””.
Hello harry,
thank you for the link, I’m sure it will be useful!
I think my RS3D has the same problem as yours. I have already disconnected and connected the blue and green board plugs. What step by step should I do?
Hello eugenio.frazao,.
Please check my rpi-shake “config.txt” and “cmdline.txt”,
you can also overwrite those files to your “/boot/”.
config.txt (1.6 KB)
cmdline.txt (113 Bytes)
Harry,
I subscribed to the “config.txt” and “cmdline.txt” files in my rpi shake. However, it continued in the same way without the information appearing on rs.local. I also disabled bluetooth. Attached is my config.txt file of my shake rpi.
CONFIG_RASP_PROBLEM.txt (1.8 KB)
