I have a Pi 3 B+ that came pre-installed with Raspberry Shake. I have noticed it’s a bit out of date, so I logged in to try upgrading packages, and here’s what I get:
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
dh-python libcomerr2 libevent-2.0-5 libpython3.5-minimal libpython3.5-stdlib python3-distutils python3-lib2to3 python3.5 python3.5-minimal
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up gpsd (3.17-7+b1) ...
Creating/updating gpsd user account...
Job for gpsd.socket failed.
See "systemctl status gpsd.socket" and "journalctl -xe" for details.
A dependency job for gpsd.service failed. See 'journalctl -xe' for details.
invoke-rc.d: initscript gpsd, action "start" failed.
● gpsd.service - GPS (Global Positioning System) Daemon
Loaded: loaded (/lib/systemd/system/gpsd.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Mar 26 01:53:21 shake.geerli.net systemd[1]: Dependency failed for GPS (Global Positioning System) Daemon.
Mar 26 01:53:21 shake.geerli.net systemd[1]: gpsd.service: Job gpsd.service/start failed with result 'dependency'.
Mar 26 02:31:07 shake.geerli.net systemd[1]: Dependency failed for GPS (Global Positioning System) Daemon.
Mar 26 02:31:07 shake.geerli.net systemd[1]: gpsd.service: Job gpsd.service/start failed with result 'dependency'.
Mar 26 02:34:13 shake.geerli.net systemd[1]: Dependency failed for GPS (Global Positioning System) Daemon.
Mar 26 02:34:13 shake.geerli.net systemd[1]: gpsd.service: Job gpsd.service/start failed with result 'dependency'.
Mar 26 02:34:48 shake.geerli.net systemd[1]: Dependency failed for GPS (Global Positioning System) Daemon.
Mar 26 02:34:48 shake.geerli.net systemd[1]: gpsd.service: Job gpsd.service/start failed with result 'dependency'.
Mar 26 02:37:18 shake.geerli.net systemd[1]: Dependency failed for GPS (Global Positioning System) Daemon.
Mar 26 02:37:18 shake.geerli.net systemd[1]: gpsd.service: Job gpsd.service/start failed with result 'dependency'.
dpkg: error processing package gpsd (--configure):
installed gpsd package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
gpsd
E: Sub-process /usr/bin/dpkg returned an error code (1)
I can’t manually start gpsd either. I don’t even have a GPS device attached (AFAICT)… how can I get past this error?
