Hi Philip,
I tried posting the code as text between quotes [quote][/quote] but it turned the #comments into headers and did some strange things, so I went back to the screenshot.
OK, after having a look at some page source code here’s the code:
from obspy import UTCDateTime
from obspy.signal import filter
# define start and end times
start = UTCDateTime(2022, 4, 11, 9, 20, 00) # (YYYY, m, d, H, M, S)
end = start + 10 # start plus plot duration in seconds (recommend a minimum of 10s)
# define fdsn client to get data from
client = Client('RASPISHAKE')
# get data from the FSDN server and detrend it
STATION = "R21C0" # station name
st = client.get_waveforms("AM", STATION, "00", "HDF", starttime=start, endtime=end, attach_response=True)
st.merge(method=0, fill_value='latest')
st.detrend(type="demean")
# get Instrument Response
inv = client.get_stations(network="AM", station=STATION, level="RESP")
# set-up figure and subplots
fig = plt.figure(figsize=(12,8)) #12 x 8 inches
ax1 = fig.add_subplot(6,2,(1,3)) #left top 2 high
ax2 = fig.add_subplot(6,2,(5,7)) #left middle 2 high
ax3 = fig.add_subplot(6,2,(2,6)) #right top 3 high
ax4 = fig.add_subplot(6,2,(8,12)) #right bottom 3 high
ax5 = fig.add_subplot(6,2,(9,11)) #left bottom 2 high
fig.suptitle("AM."+STATION+'.00.HDF Channel '+start.strftime('%d/%m/%Y %H:%M:%S UTC'))
# plot the raw curve
ax1.plot(st[0].times(reftime=start), st[0].data, lw=1)
#plot the PSD
ax2.psd(x=st[0], NFFT=512, noverlap=2, Fs=100, color='r', lw=1)
ax2.set_xscale('log')
#plot spectrogram
ax5.specgram(x=st[0], NFFT=64, noverlap=16, Fs=100, cmap='plasma')
ax5.set_yscale('log')
ax5.set_ylim(0.5,50)
# set up filter
filt = [0.3, 0.5, 10, 12] #edit filter values to suit
# remove instrument response
resp_removed = st.remove_response(inventory=inv,pre_filt=filt,output="DEF", water_level=60)
# plot the filtered and corrected, and dB curves
ax3.plot(st[0].times(reftime=start), resp_removed[0].data, lw=1, color='g')
ax4.plot(st[0].times(reftime=start), 93.979400087*abs(resp_removed[0].data), lw=1, color='b')
# set-up some plot details
ax1.set_ylabel("Counts")
ax2.set_ylabel("Power Spectral Density")
ax3.set_ylabel("Pascals (Pa) ("+str(filt[1])+" to "+str(filt[2])+"Hz)")
ax4.set_ylabel("Decibels [dB] ("+str(filt[1])+" to "+str(filt[2])+"Hz)")
ax5.set_ylabel("Frequency, Hz")
ax1.set_xlabel("Seconds after start")
ax3.set_xlabel("Seconds after start")
ax4.set_xlabel("Seconds after start")
ax5.set_xlabel("Seconds after start")
ax1.grid(color='dimgray', ls = '-.', lw = 0.33)
ax2.grid(color='dimgray', ls = '-.', lw = 0.33)
ax3.grid(color='dimgray', ls = '-.', lw = 0.33)
ax4.grid(color='dimgray', ls = '-.', lw = 0.33)
ax5.grid(color='dimgray', ls = '-.', lw = 0.33)
#adjust subplots for readability
plt.subplots_adjust(hspace=1)
# save the final figure
#plt.savefig(STATION+' HDF '+start.strftime('%Y%m%d %H%M%S UTC')) #comment this line out till figure is final
# show the final figure
plt.show()
Enjoy.
Al.
