WiFi says wrong credentials (the credentials are correct)
I am unable to start WiFi on my 1D. It says that my network credentials are wrong, when they actually are correct. Ethernet works well.
Hello Jkgarman,
It has happened in the past that some routers will reply with a “wrong credentials” even if they are correct. We are working on this for the next Shake OS release.
In the meantime, you can use this manual procedure (How to configure Wifi and USB wifi dongles from command-line) that will bypass the check that is stopping you and directly connect the Shake to the WiFi on its next reboot.
If you need any guidance, I remain available.
