What way is north RS4D
hi what way is north on the RS4D is it were the single level set screw is or is it were the two level set screws are
Thanks Randy
I found were it is marked on the board
Thanks Randy
Hello Randy,
No trouble at all!
I’ll add this in case other users have the same questions and are looking for a quick answer: if you look at both the RS3D and the RS4D through the transparent cover of the indoor/outdoor enclosure, you will see a blue board on top of the Raspberry Pi (the Shake board).
On its right side (the one opposite to all the USB and LAN ports), there is a small white arrow that has to be pointed toward the N.
Here’s a couple of images (showing the RS3D) that should help:
