How do I interpret the RS Data View linear scale in the expanded view? I can see the time is displayed in UTC on the left and my time zone (EDT) on the right. Minutes appear on the bottom. When zooming in on a specific time range the scale at the bottom represents duration. What is the scale on the left (M/S) a measure of? What does M/S stand for?
Meter per second - speed at which the ground (well, the detector) is moving…
Hello pasgaf,
Exactly as Philip has said, M/S
stands for meters per second, the unit of speed at which the ground is moving.
You can also find M/S^2
in the case of the accelerometer channels (EHN, EHE, EHZ), which is instead the unit of acceleration (rate of change of the velocity of an object with respect to time).
