Hi everybody,
I have 2 RS3D units. In the tech specs I read that they feature 24-bit ADC, i.e., theoretical 144dB dynamic range. Estimated sensitivity is 3.60e8 counts/(m/s) and (theoretical) clip level is +/- 8,388,608 counts [(2^24)/2]. This yields an estimated clip level of +/- 23.3 mm/s.
First of all, it seems to me that the clip level of 24 mm/s peak-to-peak reported in the specs is wrong. Shouldn’t it be 48 mm/s (better 47 mm/s) peak-to-peak?
Second, it is possible to know the voltage range set for the analog-to-digital conversion?
Thanks very much for your help
Diego
