VLF "vibrations"
The other day my 9-year-old granddaughter came up to me and said “my ears are vibrating”. I could not hear anything, but I knew a rain storm was approaching. A while later I checked RB and found this trace, right at that time:
This is actually quite a common occurrence when a storm passes over, or nearby. Sometimes readings up to 1E6 counts are recorded. The frequency is in the range of 0.1 Hz (my RB has the long time constant filter).
This little girl has rather sensitive ears, it seems.
Ken
That’s definitely impressive for the young lady!
My grandma could feel something similar (alas, no RBoom at the time), especially when thunderstorms were approaching in the afternoon.
I have the low frequency filter for my RS&B but I didn’t fit it initially… I need to shut it down and fit it sometime!
Al.
I didn’t fit mine either - I thought it would be better to have the wider bandwidth.
I am no longer convinced about that. Maybe R-Shake should re-think which one they fit by default?
I’ve just shut mine down and fitted the 20s filter. About time probably… lol!
Al.
FWIW Here’s a shot of the helicorder after doing the change. The difference is quite visible.
No idea what the VLF event was that I was looking at at the time. ;o)
I’d like to think that it may be possible to detect atmospheric gravity waves with this filter installed. I detected the Tonga Eruption gravity waves with my barometer, but from memory the period was longer than 20s.
Al.
The stuff you detect at these frequencies might better be termed atmospheric waves rather than infrasound.
Some of these phenomena are even much lower in frequency than what the extended-range RB can record. I suppose you could just use a barometer for that :wink:
Yes, they may well be beyond the reach of the Boom even with a 20s filter, but it’s worth a try.
Just FYI below are my barometer traces from the Hunga Tonga eruption last year (this is the event that ultimately prompted me to buy my S&B):
These were produced from Cumulus software. The Select-a-Graph unfortunately uses the archive file which only stores data every 15mins! The other graph was a screen shot of the pressure graph from Cumulus which updates the data every 10 or 15s (I can’t remember which now…) while the software is running.
While the base frequency of the wave (period of about 45 minutes or so) is too low a frequency for a Boom even with a 20s filter, I’d like to think there are some frequencies apparent in the Pressure graph that should be detectable with a Boom.
Al.
The Hunga event infrasound energy is shown in this nice spectrogram:
[source: https://www.sciencedirect.com/science/article/pii/S0012821X22002758 ]
The lower graphs are filtered for 20-100 seconds - a bandpass that just touches the range of RB with the longer mechanical filter. The right hand side graph was measured in Kenya about 1/2 way around the planet…
I think this is the corresponding trace from my RB (lots of RBoomers saw it) seems like the “tip of the iceberg”
Looking at the colorful graph, the horizontal line at 300 seconds is the BV frequency (Which has to do with gravity waves):
So I learned something obscure today :wink:
