Hello shakers!!!
I’m trying to monitor the movements of the sensor from another side, but I don’t know how to send the data using the IP, I guess it can be done with the Public IP, What methods could be used to be able to do what I try?
Hello shakers!!!
Hello Flomp,
If your Shake is connected to the wider internet (and not just to a local area network) then you can find and see its live data from our new DataView portal, here: https://dataview.raspberryshake.org/
However, if instead you are in the case where your Shake is only connected to a local LAN, then some virtual tunnel setup (or maybe a VPN) could be of help. We have some details here in our manual: How to connect to Raspberry Shake remotely — Instructions on Setting Up Your Raspberry Shake
