I am using SAMBA on many Raspberry Pi cards to access NTP logs in /var/log/ntpstats and it works very well. However, when adding the lines:
[ntp]
comment = NTP log files
path = /var/log/ntpstats
read only = no
guest ok = yes
to the smb.conf file, I get “System error 5” in Windows. I note that the smb.conf file is missing dozens of lines that the other Raspberry Pi cards have. Can I simply substitute my own smb.conf file if I retain your [group] share? This used to work until about 2019-Mar-12, so I don’t know what happened then.
would it be possible to provide your version of the file to us so we can have a look?
and / or, please feel free to try it out yourself and see what happens. the samba file was modified to deal with resolving rs.local in some instances where it was previously not working.
have a look?
Yes, I posted my configuration file, but below your text. I’ve replied separately, but the issue was resolved by reinstalling SAMBA, and copying a known good configuration file from another PC. The re-installed resulted in a completely blank configuration file which isn’t what it should do. I’ve sent you the error listing.
