USB WiFi Dongle
Appreciate this isn’t really a Shake technical matter but here goes anyway…
I recently bought this USB WiFi dongle USB WiFi Adapter for Raspberry Pi | The Pi Hut for its “Plug n’ play WiFi with the Raspberry Pi” compatibility but unfortunately it isn’t.
Have looked through this forum & manual referring to the many useful posts and guides but unfortunately http://downloads.fars-robotics.net/wifi-drivers/install-wifi is no longer online (2023-08-25 @ 14:30 hrs UTC).
The internal wifi shows but not the usb wifi dongle. Thought I’d check in here first before I attempt to find, download and install the correct driver in case anyone has a better lead.
root@raspberryshake:~# iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
vethfae0974 no wireless extensions.
veth8fb308b no wireless extensions.
wlan0 IEEE 802.11 ESSID:“MYSSID”
Mode:Managed Frequency:2.412 GHz Access Point: xx:xx:xx:xx:xx:xx
Bit Rate=72.2 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=66/70 Signal level=-44 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
docker0 no wireless extensions.
veth443233e no wireless extensions.
root@raspberryshake:~# uname -a
Linux raspberryshake 4.19.97-v7l+ #8 SMP Tue Apr 25 11:50:30 UTC 2023 armv7l GNU/Linux
root@raspberryshake:~# cat /etc/os-release
PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
root@raspberryshake:~# cat /etc/debian_version
10.3
root@raspberryshake:~# cat /proc/cpuinfo
Model : Raspberry Pi 4 Model B Rev 1.5
root@raspberryshake:~# lsusb -v
idVendor 0x148f Ralink Technology, Corp.
idProduct 0x7601 MT7601U Wireless Adapter
bcdDevice 0.00
iManufacturer 1 MediaTek
iProduct 2 802.11 n WLAN
iSerial 3 1.0
bNumConfigurations 1
Strange.
root@raspberryshake:~# lsmod | grep -i mt7601u
mt7601u 102400 0
mac80211 708608 1 mt7601u
cfg80211 647168 3 mac80211,mt7601u,brcmfmac
root@raspberryshake:~# dmesg | grep 7601
[ 1.366112] usb 1-1.4: New USB device found, idVendor=148f, idProduct=7601, bcdDevice= 0.00
[ 2.762506] mt7601u 1-1.4:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 2.763736] mt7601u 1-1.4:1.0: Direct firmware load for mt7601u.bin failed with error -2
[ 2.764439] mt7601u: probe of 1-1.4:1.0 failed with error -2
[ 2.764495] usbcore: registered new interface driver mt7601u
root@raspberryshake:~# find /lib/firmware -name “*7601*” -print
→ returns nothing
According to GitHub - art567/mt7601usta: Linux driver for MT7601U with patch for stability and performance on recent kernel versions “If you have Linux 4.2 or later the new driver is already part of the kernel (it’s called mt7601u).”
A fresh night’s sleep and a search of duckduckgo instead of google provided a lead that solved the problem.
MediaTek provide a Linux Driver on this page https://www.mediatek.com/products/broadband-wifi/mt7601u
I downloaded and extracted the files
$ wget https://d86o2zu8ugzlg.cloudfront.net/mediatek-craft/drivers/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.bz2
Searched through and found this
$ find ~/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913 -name “*7601*” -print
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/chip/mt7601.h
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/mcu/MT7601_firmware.h
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/ate/chips/mt7601_ate.c
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/chips/mt7601.c
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/chips/mt7601.c.bak
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/mcu/bin/MT7601_formal_1.7.bin
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/mcu/bin/MT7601.bin
/home/user/Downloads/wifi/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/mcu/bin/MT7601_formal_1.7_Debug.bin
Had a look
$ ls -l MT7601.bin
-rwxrwxr-x 1 user user 45412 Sep 12 2013 MT7601.bin
I wonder if this is the same size as the one on my Ubuntu 22.04 installation
$ ls -l /lib/firmware/mt7601u.bin
-rw-r–r-- 1 root root 45412 Aug 4 14:01 /lib/firmware/mt7601u.bin
It is, let’s double check they’re the same
$ md5sum /lib/firmware/mt7601u.bin
696cedb8e76ecc0cda9f9b0d3972c64d /lib/firmware/mt7601u.bin
$ md5sum MT7601.bin
696cedb8e76ecc0cda9f9b0d3972c64d MT7601.bin
What happens if I copy it over to where the missing firmware file should be and then power down / up? In this case I copied over my Ubuntu one, not as though there should be any difference.
It worked! Two wlan0 entries but we can soon sort that out.
Add this to bottom of /boot/config.txt (newer syntax):
dtoverlay=disable-wifi
Blacklist in /etc/modprobe.d/raspi-blacklist.conf
blacklist brcmfmac
blacklist brcmutil
Add the Power Management off option (and reference) to the bottom of rc.local so it now looks like this
root@raspberryshake:~# cat /etc/rc.local
# Ref Wifi Dongle - #7 by iannesbitt - turn off Power Management
/sbin/iwconfig wlan0 power off
exit 0
Power down / power up and hey presto only one wlan0 from iwconfig. Run ifconfig to check MAC address and yep that’s not the internal one.
Job done, time for breakfast.
Hello Hadders,
Just a note to thank you for showing all the steps you’ve taken to identify, address, and fix the issue you were experiencing with your USB WiFi dongle.
I’m sure it will be of help to other users in similar situations.
