Can I just unplug the USB SD card device and read the data off it on a laptop? Does the unit have to be in a certain state, power off, etc? Whats required?
thanks
thanks
Hello alexM,
If the device is turned off, then yes, you can safely remove the microSD card from the Shake and then read the data saved on it from any other computer you have available.
If the Shake is still on, instead, it should be shut down first to avoid damaging the microSD card itself. To do so:
rs.local/
or the Shake IP address in any browser from a computer connected to the same network. Then click on “Actions” (the hammer icon high on the left), “Actions” again, and then “Shutdown”.Once done, you will be able to ping and access your Shake directly and also download the data without the need to extract the microSD card. Various methods to do so are described here: How to download your data
If you cannot connect to the Shake, then you could forcibly shut it down by disconnecting the power supply directly, but I wouldn’t recommend this unless it was the last available option, as it could damage the files on the microSD card.
If you require anything else, I remain available.
Perfect, thank you so much!
You’re more than welcome!
