I would like to be able to set the UPD via a python or bash script instead or in addition to use the web page. Is it possible ?
The reason is that I want to use the UDP flow locally, on the raspberry itself and I need to know what is the IP address and then set the UPD to that address it is using at that moment.
thanks
Alessandro
