Greetings,
I recently updated the image on my Shake & Boom and was unaware that it was not on the network until I started receiving emails that my Shake & Boom had not been contributing anything to the community. I am not sure the issue as I rebooted the Shake & Boom and watched on a monitor connected to it as it went through the boot process and then to a login prompt. I then tried to access the web interface via the unit’s IP address or the rs.local. I see it connected to my network on the router. What am I missing? Thanks
Good morning.
Can you send us the log files (these will need to be downloaded manually if you cannot access rs.local, see here for instructions) and the station name.
Thank you!
branden
Good afternoon,
I will follow instructions provided to access log file and submit. Thanks
