Leonard writes:
I have unplugged and replugged my shake several times to no avail. What more can I do?
Leonard writes:
This sounds like a case of SD card corruption. One way to prevent this is to use a commercial-grade SD card (called MLC) such as this Kingston card or this Transcend card. If you choose to go this route, you will need to burn the Shake OS to the card using these instructions.
We also sell pre-burned cards in our shop, if you’re looking for a plug-and-play solution.
This page in the manual has more information on Shakes and SD cards: https://manual.raspberryshake.org/burnSD.html#how-do-i-know-that-my-microsd-card-is-corrupt-and-needs-to-be-replaced
Thank you. I will order apre-burned card, but in the meantime have ordered a 3D system To replace my 1D system. I hope to be back on the air soon. Again, many thanks.
