I have a 1D that is a few months old but have been unable to connect via : rs.local or raspberryshake.local or http://192.168.1.14 (it’s IP address from my router).
I tried the 1D initially on a RaspberryPi B original and then on two different model 2 B versions. Neither had much on time, so doubt the SD card is worn out.
I’m able to ping the board and get a response at the 192.168.1.14 IP address. I have loaded two different versions of the Bonjour server software links in another rs.local problem thread. I also have the Advanced IP Scanner which gives me confirmation of the .14 IP address and that it is “live”.
I’ve tried Chrome and Firefox with rs.local, raspberryshake.local, and http://192.168.1.14 andwith the :5000 port called out. All either say “refused to connect” or “This site can’t be reached”. rs.local just goes to a white screen as does raspberryshake.local.
I tried three different PCs with three different operating systems: Win7, Win10, Ubuntu.
The lights on the RaspberryPi and 1D daughter card show powered on and connected to the router. Not sure if any updates have happened. But have left them on long enough that anything should have completed if it was going to.
I tried some of the commands in the SSH comments unsuccessfully. Have rebooted everything a number of times in the past few days.
Not sure what to do next. But rebuilding the SD card is a bit beyond my understanding so far.
Every help session string seems to end in success long before I get to anything that works for my three RaspberryPi’s.
Thanks for any ideas you can give me.
Charles O
