I have recently obtained a new RS3D (outdoor).
For increasing its storage I plugged in a USB drive to the RS and followed the steps provided here: How to mount a USB to store the waveform archive — Instructions on Setting Up Your Raspberry Shake
After this, the data was being saved to the USB as well as streamed online. However after I removed the USB following the steps provided on the webpage, I am no longer able to access my RS. The green light is blinking, so its pinging my wifi router (wifi server also shows that RS is connected) but nothing pops-up when I access RS using http://rs.local or through ssh.
I am expecting that this happened because I turned off consumer and producer services. I there any way to turn them back on and test?
Note:
I have 2 other RS that are connecting through the wifi perfectly fine.
Related question:
Should I have had turned the stand-alone mode ON before following these USB steps?
