Hi.
My computer time shows for example 15.00h. The time on RS config is 14.58h.
-2 minutes off…
Where is the problem
Here LOGS:
RSH.RCF63.2024-01-15T14 33 49.logs.tar (4.2 MB)
Marco
Hi.
-2 minutes off…
Here LOGS:
Marco
Problem solved, sorry…
Marco
Hello Marco, no problem at all!
If you want, can you share what the problem was and how you solved it? In this way, other Shakers with a similar issue could find the solution in your answer.
Hi.
Synchronization of the clock on the computer has been turned off.
I did not see this b4…
Marco
