Hello ozanguven, welcome back to our community.
Thank you for the logs from your Shake. It seems that, similarly to Sean’s case, the fact that the Shake displays a Booting status is not impacting its data recording and transmission. With an equivalent approach, the Booting issue would be likely solved by re-burning the Shake OS on the microSD card. As things are still running fine, I would not advise doing it at this stage, but if you want to do it in any case, here’s the link where you can find the necessary files and all the instructions to burn it: raspberryShake-public / Raspshake Sd Img · GitLab
Regarding your points, I will answer them one by one for clarity:
- & 2) This is related to a server issue our team has been working to fix since last week, and that is causing Shakes to appear as offline, with delayed data display or data interruptions. As soon as the problems are corrected, the
Offlinemessage and the data gaps will disappear. - Our new
QuakeViewproduct will show randomized stations regarding any earthquake in any region of the world, so that the Shakes that appear will always be different (if there is a high enough number of them), giving every Shaker the chance to be displayed in one of the plots.
EDIT: our team reminded me that there is also another fix for the Booting Status, with the procedure to apply it explained step-by-step here System Version: 0.20, System Status: Booting - #8 by ivor and the file to download for the procedure here: System Version: 0.20, System Status: Booting - #12 by ivor
