When I click MyShake, my station does not appear under it. It is blank. But I can find my station under “Raspberry Shake”. How do I make it that I can access my shake under “MyShake”. This has only happened recently, before I could access it under MyShake.
As Marco said, you can copy the old .config file and everything should go back to normal.
If not, you can click right on the myShake name in the list, and see if, maybe, the connection details have been modified for some reason. If they are, you can replicate what you had in the previous SWARM installation and the Shake should appear again.
As of now, we advise using our new DataView portal, here: RS DataView BETA as SWARM will not receive any more updates from the USGS (the original developer and maintainer)
And, if you see something that is missing in DataView that you found useful in SWARM, or some functionality that you would like to have available, please let us know!
I do find the pick option quite useful in swarm as that is able to estimate duration magnitude as well as estimating distance of earthquakes using the P and S wave picks.
