Hi all,
I am trying to make the menus much larger in Swarm. Right now when I run the Swarm console they are tiny! Normally to solve this I would create a Windows manifest file in XML to instruct Windows to ignore App Scaling on high DPI displays. However you can only do that with the usual Windows executable files (.exe). Swarm, however, runs under Java and I’m not not sure how to correct this.
Has anyone had similar issues and is there a workaround that will display the Swarm menu at the correct size?
Thanks
Steve
