using ReadMSEEDFast. I’ve been using my code for three years now with no read problems. Now, starting 2020 day 100 I get this read error. No problem reading 2019 day 100 or any day in 2020 before 100. Was there a software change resulting in a change in write format to seed files?
Index in position 1 exceeds array bounds.
Error in ReadMSEEDFast>DecodeSignal (line 314)
signalMatrix=reshape(signalMatrix,numel(encodedSignalMatrix(1,:))/4,[]);
Error in ReadMSEEDFast (line 179)
[signalMatrix,timeVector]=DecodeSignal(encodedSignalMatrix,ENCODING,isLittleEndian,BLOCK_RECORD_SIZE,headerInfoAllVolumes.startTime(sameChannelRows,:),headerInfoAllVolumes.sampleRate(sameChannelRows,:));
i don’t know what ReadmSEEDFast is so i can’t really comment on that code itself. (on a side note, i do find that function name interesting: is there a slow version?)
and i can confirm that there’s been no change to how mini-SEED format files are written, this is code that is probably more than 20 years old.
i would suggest contacting the person responsible for the function you refer to and asking them if they can provide any further insight into why it’s failing.
