Strange Glitch in RS.Local
As you Can See, the Bracket between “EHZ” has been switched around.
Hello Xtremeo,
That particular bracket has been put there on purpose. As you can see, all the channel acronyms have the letter “E” in common, so instead of repeating it, it has been put outside the brackets.
In this way, the notation with the brackets reads as EHZ, ENZ, ENN, ENE.
Hope I was able to clarify this for you. If not, feel free to ask other questions you may have.
