Im trying to use the Raspberry map and only around 20 stations are showing up. I dont know if theres an issue with the site or if its from my end (I live in a remote area in Northern Alberta) any help or an answer would be greatly appreciated
thanks
thanks
hi,
we are in the process of doing some maintenance on our data servers, so this is likely due to a synchronization / coordination issue. we will look into it and get it solved.
in the meantime, be rest assured all the data from the network is still being recorded, this problem relates to the display on the webpage only.
sorry for the inconvenience,
