StationView - not showing earthquakes
A the subject line says, I don’t see a single earthquake showing in StationView.
Pretty sure it was working earlier this morning.
Is this me? or is is a server/database problem?
Hello PhilipPeake,
Thank you for reporting this to us, I have corrected the issue, and you should be able to see the earthquake list back on StationView in the next minutes.
Please do a Ctrl+F5 or Mac equivalent if the events still do not show after 5-10 minutes.
Thank you again.
Thanks - I saw the events pop up at about the same time as I saw your message.
Thanks for the quick fix!
Philip
No problem at all, you’re welcome!
