What is the criteria for relevance? As in the mobile app, I should see also local earthquakes, but I do not.
Kind regards
Hello jheiler,
Let’s see, this is the logic that is being used when a “Relevance” sorting is selected.
- Obtain lat/lon
- If a station is selected, StationView will use the lat/lon of that station.
- If no station is selected, then use the lat/lon from the browser’s address bar, which corresponds to the center of the currently displayed map
- Calculate Relevance values for all events
- calculate the distance (in degrees) between all visible event locations and the location obtained from point 1.
- Then calculate the Relevance value using this formula (provided by a seismologist):
const d = Math.pow(4.6403, 2);
RelevanceValue = Math.pow(10, e.mag - 3.9720 - 2.1577 * Math.log10(Math.sqrt(Math.pow(dist, 2) + d)));
- For last, all events are then ordered so that the one with the larger
RelevanceValueappears first.
If I compare my station list on StationView with the list that appears on the Mobile App, I get the same values. Are you instead seeing discrepancies between the two?
As you can see in the screenshots, I selected my station. If I sort the events by distance, two local events are shown, they are not sorting by relevance.
In the android app, the views are correct in this sense.
Kind regards
Thank you jheiler.
Could I ask you to send a screenshot of what you can see from your Mobile App when you sort by “Relevance”?
As I cannot recreate the issue on my side, I would like to send our software team all possible info so that they can take a look at what is happening.
Thank you very much jheiler; it’s exactly what I needed.
I’ll forward them to our team so that they can crosscheck between the two and see what is going on.
I’ll update you again when I’ll get news from them.
