Station AM.R309F was working fine, then just turned “black”. Tried restarting, no change. I can see it ok with Swarm, it is showing connected, and I don’t see any obvious errors in the logs.
EDIT: Maybe relevant - Earlier in the day I moved the device from the house basement to our pole barn to avoid the noise/vibration from the house HVAC. A move of maybe 75 feet - I adjusted the location to match. It worked for several hours after this.
Yes, it was due to exactly that. After one station is disconnected for a certain period of time, and then reconnected, it may take up to 24h before it reappears on our services.
