Hello VS1,
Thank you for the logs. From them, it appears that every now and then the internet connection was not available, and this caused some Hard Resets that rare troublesome in getting a constant stream of data to our servers. Here you can see an example:
2021 045 06:10:54>> Time adjustment M0: HARD RESET. This will result in a one-time time-tear.
2021 045 06:10:57>> 5.0: NTP Time (Init): NTP: 1613283052.825454950
2021 045 06:10:57>> 5.2: NTP Sync (HARD): VEL Before: 1613282958.063999891 After: 1613283052.565000057 Diff: 94.501000166
2021 045 06:10:57>> 5.2: NTP Sync (HARD): ACC Before: 1613282958.063999891 After: 1613283052.565000057 Diff: 94.501000166
Can I ask what caused the Shake to go offline for the first time? Was it something like a power cut, or another reason?
Something that you can try, if you haven’t already, is to shut down your Shake first, then your modem/router. Wait for 2 to 5 minutes, then restart your modem/router, and when it’s back online, please check from your pc/laptop if the following ports are open (do not start the Shake now) if you can:
port 55555 [TCP]
port 55556 [TCP]
After checking this (sometimes the modems close them without prompting) and opening the ports, if needed, please start your Shake, wait for around 10 minutes and then let’s check that your unit can reach our servers. Can you SSH (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake) into the Shake and try and ping the following addresses?
ping 8.8.8.8 -c 10
ping 104.200.16.60 -c 10
Also, please download the logs again and attach them to your answer, so that I can compare any difference between the old and the new ones.
