It has been some time since we have had any discussion on this topic. I thought I should post the full code so that others can try it.
This requires the user to find the events manually and pick off the arrival times. Approximate locations of the stations can be found in the online instrument response XML files. A further development of this could be to automate gathering of lat/lon data from station names. Of course, precise locations would be better - if you knew them.
# Algorithm by Raspberry Boom member "dizcza"
# Posted by kpjamro
# For 3 or more sound arrival times, at 3 or more locations
# this python routine estimates the source location and time
# with more than 3 stations, it selects the best combination of 3 ('triplet')
import geopy.distance
from geopy.distance import geodesic
import numpy as np
from scipy.optimize import fsolve
from itertools import combinations
from datetime import datetime
import time
def localization_impossible(coords, arrivals, v_min=300):
ii = np.array(list(combinations(range(len(coords)), r=2)))
# remove the same stations
mask = np.linalg.norm(coords[ii[:, 0]] - coords[ii[:, 1]], axis=1) > 1e-6
ii = ii[mask]
possible = []
for i, j in ii:
dist = geopy.distance.geodesic(coords[i], coords[j]).m
t_diff = abs(arrivals[i] - arrivals[j])
possible.append(t_diff < (dist)/v_min)
return sum(possible) < 3
def time_source_func(coords, arrivals, source, v):
dist = np.array([geopy.distance.geodesic(source, xy).m for xy in coords])
t_source = arrivals - dist / v
return t_source
def get_time_best(t_source2d):
zero_vec = t_source2d[:, [0]] - t_source2d[:, 1:]
cost = np.abs(zero_vec).sum(axis=1)
argmin = cost.argmin()
return t_source2d[argmin]
def get_best_triplet(t_source, ii):
t_source2d = t_source[ii]
return ii[argmin]
def solve_bounded(source, *args):
coords, arrivals, v, ii = args
t_source = time_source_func(coords, arrivals, source, v)
t_source = get_time_best(t_source[ii])
zero_vec = t_source[0] - t_source[1:]
return zero_vec
def get_triple_indices(coords):
ii = np.array(list(combinations(range(len(coords)), r=3)))
pairwise_dist = np.linalg.norm(coords[ii[:, [0]]] - coords[ii[:, 1:]], axis=-1)
mask = (pairwise_dist > 1e-6).all(axis=1)
ii = ii[mask]
return ii
def localize_source(coords, arrivals, v=330):
# coords: [lat, lon] N pairs
# arrivals: [t0, ... t_N-1]
def solve_unbounded(source, *args):
if np.abs(source).max() > 90:
return np.array([1e9, 1e9])
return solve_bounded(source, *args)
if localization_impossible(coords, arrivals):
return None, None, None
ii = get_triple_indices(coords)
res, info, status, message = fsolve(solve_unbounded,
x0=coords.mean(axis=0),
args=(coords, arrivals, v, ii),
full_output=True)
if status != 1:
# res, t_source = localize_source_bounded(coords, arrivals, v=v)
res, t_source, triplet_best = None, None, None
else:
# print(np.abs(info['fvec']).sum())
t_source = time_source_func(coords, arrivals, source=res, v=v)
triplet_best = get_best_triplet(t_source, ii)
t_source = t_source[triplet_best].mean()
prop = {
"triplet": triplet_best
return res, t_source, prop
# ===== enter data here =============================== #
sound_speed = 343.0
# station location lat, lon
stations = np.array([
[39.027, -76.887],
[38.991, -76.086],
[38.874, -77.340],
[38.757, -77.058]
# corresponding arrivals "dd/mm/yyyy hh:mm:ss.fff" **UTC**
arrivals = np.array([
"4/6/2023 19:08:56.072",
"4/6/2023 19:08:48.315",
"4/6/2023 19:09:52.600",
"4/6/2023 19:08:58.846"
# ===== end of data section ==============================#
# the "program" #
print("Input arrival times")
for n in range(0, len(arrivals)): print(arrivals[n])
ats = []
ar = []
# change date/time format to seconds in epoch including fractional seconds
arrstr = str(arrivals[n])
ats.append(time.mktime(datetime.strptime(arrstr, "%d/%m/%Y %H:%M:%S.%f").timetuple()))
a = (datetime.strptime(arrstr,"%d/%m/%Y %H:%M:%S.%f"))
ar.append(a.microsecond/1e6 + ats[n])
arrivals = ar
print("\nArrival times converted to uSec ")
for n in range(0, len(arrivals)): print(ar[n])
print("\nStations ")
for n in range(0, len(arrivals)): print(stations[n])
# this does the work:
source_estimated, t_source_estimated_seconds, prop = localize_source(coords=stations, arrivals=arrivals, v=sound_speed)
print("\nEst. loc. and date/time of event =\n", source_estimated, " ", time.ctime(t_source_estimated_seconds))
print("\n selected",prop)
# end of file ======================================================
here is a sample output from the data contained in listing
python source_loc.py
Input arrival times
1685920136.072
1685920128.315
1685920192.6
1685920138.846
Stations
[ 39.027 -76.887]
[ 38.991 -76.086]
[ 38.874 -77.34 ]
[ 38.757 -77.058]
[ 38.87739603 -76.92202799] Sun Jun 4 19:08:06 2023
selected {'triplet': array([0, 2, 3])}
(the end)
