I am buy DIY RS and starting with RPI 4 B. In first start and config its OK. But after change SSH password server connection is not working. After restart RS is infinit loop. Set static IP is not possible.
I back SSH password to default “shakeme”, but problem persisting.
I am very disappointing!
Hello antebosnjak, welcome to the community!
Thank you for the logs. From them, it appears that the DNS address ‘89.139.103.3’ is not getting a connection to our servers. These lines make the issue clear:
2021 017 19:18:38: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
2021 017 19:18:38: No internet connection found
2021 017 19:18:48: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
The first thing you can try, if you haven’t already, is simply to shut down your modem/router, wait a couple of minutes, and then turn it on again, to see if it was a simple issue with the modem/router itself.
If this has not solved the issue, then please shut down your Shake again first, then your modem/router. Wait for a couple of minutes, then restart your modem/router, and when it’s back online, please check from your pc/laptop if the following ports are open (do not start the Shake now):
port 55555 [TCP]
port 55556 [TCP]
port 123
for TCP
and UDP
traffic in both directions
If the connection still doesn’t work, then you can also try to change the DNS on the Shake, as explained in this page on our manual, Firewall issues? — Instructions on Setting Up Your Raspberry Shake, to see if this solves the issue. I’ll add some more info below.
There are two possible ways: setting a manual IP and DNS in the http://rs.local web config, or adding a line to /etc/dhcpcd.conf
in the Shake filesystem.
The first doesn’t require logging into the Shake. Navigate to
rs.local
, make note of the Shake’s IP address, then click on theSettings
gear icon (high on the left) to access the configuration menu.Click on NETWORK, then under ETHERNET SETTINGS, click on “Enable static IP”.
Fill out the DNS server field with a more reliable DNS service.
OpenDNS
, which is208.67.222.222
, is a good choice. You can also useCloudflare
DNS service by entering1.1.1.1
orGoogle
by entering8.8.8.8
SSH into the Shake (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake)
sudo echo 'static domain_name_servers=1.1.1.1 1.0.0.1' >> /etc/dhcpcd.conf sudo service dhcpcd restart
nano /etc/resolv.conf
# Generated by resolvconf nameserver 1.1.1.1 nameserver 1.0.0.1
