My UPS whined (loudly and steadily) that it’s time for a new battery. Maybe something about recent -27°C low temperatures outside the unheated garage. My RSB was running fine. Go inside, shutdown the RSB via web interface, go to garage, remove UPS, plug router and RSB into wall outlet.
Go inside, RSB up, helicord display works, Dataview shows no new data. The RSB had come up before the router, so reboot RSB via web page again - no change.
From the RSB today:
$ ping -c 2 raspberryshakedata.com
PING raspberryshakedata.com (144.91.66.87) 56(84) bytes of data.
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=1 ttl=54 time=113 ms
64 bytes from ip-87-66-91-144.static.contabo.net (144.91.66.87): icmp_seq=2 ttl=54 time=109 ms
Web home page shows:
|Data Forwarding|:|ON|
|Server Connection|:|Not Connected|
Best clue I can find in log files is in odf_SL_plugin.log where it shows the DDS Destination is gone:
2021 294 13:47:49>> odf_SL_plugin: Program Starting…
2021 294 13:47:49>> Version: 2020.045
2021 294 13:47:49>> Run-time parameters:
2021 294 13:47:49>> Data Source: INSTRUMENT
2021 294 13:47:49>> Network Code: ‘AM’
2021 294 13:47:49>> Station Code: ‘RB3C2’
2021 294 13:47:49>> Serial Port: ‘/dev/ttyS0’
2021 294 13:47:49>> VEL SR: 100 hz
2021 294 13:47:49>> ACC SR: 0 hz
2021 294 13:47:49>> IS SR: 100 hz
2021 294 13:47:49>> Data Destination 1: DDS
2021 294 13:47:49>> Host: raspberryshakedata.com
2021 294 13:47:49>> Port: 55555
2021 294 13:47:49>> Data Destination 2: UDP
2021 294 13:47:49>> Data Destination 3: SEISCOMP
2022 028 21:54:09>> odf_SL_plugin: Program Starting…
2022 028 21:54:09>> Version: 2020.045
2022 028 21:54:09>> Run-time parameters:
2022 028 21:54:09>> Data Source: INSTRUMENT
2022 028 21:54:09>> Network Code: ‘AM’
2022 028 21:54:09>> Station Code: ‘RB3C2’
2022 028 21:54:09>> Serial Port: ‘/dev/ttyS0’
2022 028 21:54:09>> VEL SR: 100 hz
2022 028 21:54:09>> ACC SR: 0 hz
2022 028 21:54:09>> IS SR: 100 hz
2022 028 21:54:09>> Data Destination 1: UDP
2022 028 21:54:09>> Data Destination 2: SEISCOMP
From odf_SL_plugin.err:
| 2022 028 09:56:34>> | sendDClientDP(): Error sending data … |
| 2022 028 09:56:35>> | sendDClientDP(): Error sending data … |
| 2022 028 09:56:35>> | Connection request (raspberryshakedata.com:55555) failed with error code: Connection refused |
Hmm. The garage router uses WiFi to my main router, I wonder if its NAT data is confused.
Is there a safe way to try connecting to the server? In the meantime I’ll stick to observing and not poke things outside of my LAN.
I have rebooted my RSB before without incident, I was not expecting difficulty this time. I’ll figure out how to upload the current log tar file.
