how do I shutdown my RS4D and restart it ?
Need to move it
Thanks Randy
Need to move it
Thanks Randy
Hello Randy,
You have different options to shut down your RS:
rs.local/ by typing this address in your browser (or the Shake IP address, if you know it). Then click on the Action icon (hammer) high on the left, again on the Action tab, and select Shutdown.sudo shutdown now to turn off the Shake.Once your Shake is turned off, you can disconnect the power and Ethernet cables from it and move the instrument to your desired location.
Then, reconnect the Ethernet cable first and the power cable second, and the Shake will start up again on its own (unless you have a switch on the power cable that you need to press/activate).
