I woud like to see all raspshakes in seiscomp. I imported https://fdsnws.raspberryshakedata.com/fdsnws/station/1/query?net=AM&endafter=2021-01-01&level=resp&format=sc3ml and configured:
==> /opt/seiscomp/etc/key/global/profile_raspshake <==
# Defines the channel code of the preferred stream used by e.g. scautopick and
# scrttv. If no component code is given, the vertical component will be fetched
# from inventory. For that the channel orientation (azimuth, dip) will be used.
# If that approach fails, 'Z' will be appended and used as fallback.
detecStream = EH
==> /opt/seiscomp/etc/key/seedlink/profile_raspshake <==
# Activated plugins for category sources
sources = raspshake:caps
# CAPS URL to fetch data from, format: [[caps|capss]://][user:pass@]host[:port]
sources.raspshake.address = capss://...:[email protected]:18004
==> /opt/seiscomp/etc/key/station_AM_R0087 <==
# Binding references
global:raspshake
seedlink:raspshake
==> /opt/seiscomp/etc/key/station_AM_R00A4 <==
global:raspshake
seedlink:raspshake
==> /opt/seiscomp/etc/key/station_AM_R00B9 <==
global:raspshake
seedlink:raspshake
==> /opt/seiscomp/etc/key/station_AM_R00DC <==
global:raspshake
seedlink:raspshake
==> /opt/seiscomp/etc/key/station_AM_R00F5 <==
global:raspshake
seedlink:raspshake
etc for all stations… I activated seedlink, did seiscomp update-config, but I can’t get anything in slinktool -Q : .
I modified Giuseppe’s post, removing this comment as I am also unsure what he meant by it.
The real-time streaming service and CAPS to SeisComP link is a paid service.
You can visually see any of your stations streaming in real-time on the ShakeNet web app and any station on the ShakeNet mobile app, but all streaming of data to an institute’s SeisComP system is a paid service. Feel free to email me if you would like a quote.
I’d be interested as well to stream the data to my institute’s Seiscomp.
I’d like to explore a custom solution. I understand that you have a paid service, however, I’m on a budget.
Could you maybe provide some direction on how to go about it for building a custom likewise integration.
thanks, @branden.
So, just to clarify, the paid service that you offer is the streaming of the data to SeedLink or the real-time usage of the data of other RPi Shakes?
