I am unable to detect my Rasp Shake [Raspberry Shake AM.R763C] on my ShakeNet mobile app, even after having it switched on for several hours.
Could you kindly look into this and help me fix this issue?
Thanks
hello,
your unit connected to the data server for the last time on 22-feb; the connection timed out one hour later. your unit has not reconnected since.
a reboot of the unit may solve the problem, depending on what it is, but in order to know exactly what is going on, we need your log files. these can be downloaded from the main page of the front-end configuration screen.
