Shake OS v0.21.1 released!
Raspberry Shake is happy to announce that the latest Shake OS update has been released!
The current update cycle should be completed in the next couple of days. Remember, if your Shake is connected to the internet, you don’t have to do anything, as the update will automatically reach your instrument! If your instrument still remains on v0.21 by then, a quick reboot (while still connected to the internet) is all that is required.
Check all the release notes below!
V21.1 Release Notes Shake-OS Modifications:
  1. Helicorder Config File Bug Fix - V21 introduced a bug that created a wrong configuration file for some instrument types, this is fixed
  2. GPS Module Detection - Algorithm has been tightened to avoid false positives, in the case when something not a GPS module is connected to the USB port
rs.local/ Dashboard Modifications:
Bug Fixes:
  1. Empty dashboard / data fields bug fix - all values now guaranteed to be saved in the proper format to avoid incorrect display
  2. Manual Location Data Input bug fix - inputting manual GPS coordinates would not result in values being properly saved
  3. Data Cast Saving: first line of user input would fail to be saved, resulting in no data being delivered on that port
  4. DataView hyperlink error: hyperlink is now correctly constructed
General Improvements:
  1. All traffic is now routed through port 80, alleviating the need to handle non-standard ports when routers and firewalls may exist between the shake and the computer running the FE Dashboard
  2. Better detection of Shake status to avoid displaying false and / or misleading messages
  3. General UI improvements and updates
As always, we welcome your feedback!
If you find anything that does not appear to be working as it should, please open a new topic (after searching if another Shaker has already done so) on the forum, putting [v21.1] in the title.
Thank you again for all your constant support and enthusiasm. Happy Shaking!
