I’m happy to announce that the next version of our Shake OS, v0.20, has been released today!
Remember, Raspberry Shake updates are automatic and do not require you to do anything. As long as your Shake is connected to the internet, it will automatically update within a week’s time. If you want/need, instead, to update your Shake manually, the v0.20 image will be made available later in the month.
This is the list of bug fixes that v0.20 will bring to all our users:
Bug Fixes
- FE config screen (rs.local/) could sometimes be blank on 1st-time system startup.Now there are measures to prevent this.
- Data Forwarding option would get turned OFF when rebooting the unit using the FE config ACTIONS button. This issue has been resolved.
This release also contains some under-the-hood improvements and general maintenance modifications.
And, to conclude, a sneak peek at upcoming functionality improvements planned for the next releases:
- Convert outgoing data format and protocol to provide the following
- Five times reduction in data packet size
- more stable connection to servers
- automatic back-filling of data when a connection is temporarily lost due to network issues
