Shake Dead on Arrival?
Hello Raspberry Shake Team,
I’m having persistent issues with my RS1D.
After a fresh SD image installation and even trying a different Raspberry Pi 3B, the system still shows no data on the web interface (rs.local is blank).
Here are the key details:
  • Model: RS1D
  • Station Code: R4998
  • Raspberry Pi: 3 Model B+
  • Image version: 0.20 (freshly installed)
  • Power supply: 5 V / 2.5 A verified stable
  • Network: Ethernet connected and stable
From the logs:
RSH.R4998.2025-10-23T17_58_39.logs.tar (3.8 MB)
  • odf_SL_plugin.err repeatedly shows:
No Data has been received from the MCU in 12 read attempts.
It appears the MCU is not transmitting data. This is a fatal condition...
Data has been successfully received, fatal condition resolved.
  • seedlink.log repeatedly reports [odf] terminated on signal 8 and restarts.
  • rsh-data-producer.log indicates /opt/seedlink/acquisition/seedlink/R4998 not found, confirming no live data stream.
This behavior persists after full power cycles, reseating the Shake board, and using a known-good SD card and Pi.
It seems the MCU on the RS1D board is intermittently failing.
Could you please confirm if this points to a hardware fault with the digitizer module, and advise on repair or replacement options?
Regards,
Charlie
Hello kitesurfercharlie, and welcome to our community.
I’m sorry to read about the issues with your freshly installed Shake, and thank you very much for your super-detailed post, and for attaching the logs from the Shake. Let’s see what we can do.
From them, it appears that the very first boot was somewhat successful
2025 296 15:41:10: Discovered Instrument: RSHAKE.1DV6
2025 296 15:41:10: Ethernet is ON and WiFi interface is disabled. To enable, see file /opt/settings/user/enable-wifi.conf
2025 296 15:41:11: Retrieving IP Address of interface eth0: 192.168.1.230
2025 296 15:41:12: Retrieving MAC Address of interface eth0: b8:27:eb:43:49:98
2025 296 15:41:12: Defining Station Name: R4998
but then, a short time later, (as you also have seen), a lot of “gibberish” pops out:
2025 296 17:41:17>>	$QLE!H‹W%S…‘EQâE!‰E
2025 296 17:41:17>>	YªQ
2025 296 17:41:17>>		16235	267
2025 296 17:41:17>>	No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data.  This is a fatal condition and should be investigated if this condition persists!
2025 296 17:41:17>>	Data has been successfully received, fatal condition resolved.
These are usually associated with a lack of power supply and/or possible microSD card corruption (which, in turn, can be caused by the same insufficient power arriving at the Shake).
I would recommend a second check to the current power supply to see if it continues to deliver a stable voltage between 5.0 and 5.2V and a current of at least 2.5A at all times (3.0A if the Raspberry Pi board that is being used is a RPi4), as a decrease in power could lead to data services interruption.
If you haven’t already tried this too, test with another Pi power supply that you know is in working condition, please try exchanging the current one with that and see if the Shake now appears more stable. Also, try changing the socket the power supply is connected to.
A second check that you can do is to see what is the behavior of all the Shake’s LEDs during booth. Does it follow what is listed here, or does it deviate before/after some point?
As a last test, you try the following procedure?
  • turn off your Shake
  • disconnect all cables from it
  • restart your router (if possible) and wait for it to regain internet connection
  • now reconnect LAN and power cable to the Shake in this order
  • turn on the Shake again
Then, wait for about 30-60 minutes and, when you can, download the new logs from both instruments and send them to me. I would like to see if there are any differences compared with the current log set, and also what the logs show after a full, fresh, restart.
